A topoSetCellSource to select all the cells from given cellSet(s).
| input | cellSet(s) | $FOAM_CASE/constant/polyMesh/sets/<set> |
Example of the cellToCell topoSet by using actions sub-dictionary in system/topoSetDict file:
name <name>;
type cellSet;
action <action>;
// Mandatory entries
source cellToCell;
// Select either of the below
// Option-1
sets
<cellSetName1>
<cellSetName2>
// Option-2
set <cellSetName>;
| source | Source name: cellToCell | word | yes | - |
Options for the action entry:
Entry | Description | Type | Required | Default sets | Names of input cellSets | wordList | conditional | - set | Name of input cellSet | word | conditional | -
Copyright © 2020 OpenCFD Ltd.
