A topoSetCellSource to select all cells whose cell centre inside a given bounding cylinder or cylinder annulus.
Example of the cylinderToCell topoSet by using actions sub-dictionary in system/topoSetDict file:
name <name>;
type cellSet;
action <action>;
// Mandatory entries
source cylinderToCell;
p1 (<p1X> <p1Y> <p1Z>);
p2 (<p2X> <p2Y> <p2Z>);
radius <radius1>;
// Optional entries
innerRadius <radius2>;
| source | Source name: cylinderToCell | word | yes | - |
| p1 | Coordinate of one of the endpoints | vector | yes | - |
| p2 | Coordinate of the other endpoint | vector | yes | - |
| radius | Cylinder outer radius | scalar | yes | - |
| innerRadius | Cylinder inner radius | scalar | no | 0 |
Options for the action entry:
Copyright © 2020 OpenCFD Ltd.
