A topoSetCellSource to select all cells based on usage in given faceSet(s), e.g. select cells that are the owner/neighbour/any of the faces in a given faceSet.
| input | faceSet(s) | $FOAM_CASE/constant/polyMesh/sets/<set> |
Example of the faceToCell topoSet by using actions sub-dictionary in system/topoSetDict file:
name <name>;
type cellSet;
action <action>;
// Mandatory entries
source faceToCell;
option <option>;
// Select either of the below
// Option-1
sets
<faceSetName0>
<faceSetName1>
// Option-2
set <faceSetName>;
| source | Source name: faceToCell | word | yes | - |
| option | Selection type - see below | word | yes | - |
Options for the action entry:
Options for the option entry:
all | Cells that are either owner or neighbour of given faces any | Cells that are either owner or neighbour of given faces owner | Cells that are owner of given faces neighbour | Cells that are neighbour of given faces
Entry | Description | Type | Req'd | Dflt sets | Names of input faceSets | wordList | cond'l | - set | Name of input faceSet | word | cond'l | -
Copyright © 2020 OpenCFD Ltd.
