A topoSetCellSource to select cells based on master or slave side of given faceZone(s).
| input | faceZone(s) | $FOAM_CASE/constant/polyMesh/faceZones |
Example of the faceZoneToCell topoSet by using actions sub-dictionary in system/topoSetDict file:
name <name>;
type cellSet;
action <action>;
// Mandatory entries
source faceZoneToCell;
option <option>;
// Select either of the below
// Option-1
zones
<faceZoneName1>
<faceZoneName2>
// Option-2
set <faceZoneName>;
| source | Source name: faceZoneToCell | word | yes | - |
| option | Selection type - see below | word | yes | - |
Options for the action entry:
Options for the option entry:
master | Master side of the faceZone slave | Slave side of the faceZone
Entry | Description | Type | Requiredd | Default zones | Names of input faceZones | wordList | conditional | - zone | Name of input faceZone | word | conditional | -
The order of precedence among the conditional mandatory entries from the highest to the lowest is zones, and zone.
Copyright © 2020 OpenCFD Ltd.
