A topoSetCellSource to select cells based on volScalarField values, i.e. select cells with given field value of >= min and <= max.
| input | volScalarField | $FOAM_CASE/<time>/<inpField> |
Example of the fieldToCell topoSet by using actions sub-dictionary in system/topoSetDict file:
name <name>;
type cellSet;
action <action>;
// Mandatory entries
source fieldToCell;
field <fieldName>;
min <minFieldValue>;
max <maxFieldValue>;
| source | Source name: fieldToCell | word | yes | - |
| field | Name of volScalarField to use | word | yes | - |
| min | The min value for the subset | scalar | yes | - |
| max | The max value for the subset | scalar | yes | - |
Options for the action entry:
Copyright © 2020 OpenCFD Ltd.
