A topoSetCellSource to select cells attached to the outside of this cellSet, and add into/remove from this cellSet.
| input | cellSet | $FOAM_CASE/constant/polyMesh/sets/<set> |
Example of the haloToCell topoSet by using actions sub-dictionary in system/topoSetDict file:
name <name>;
type cellSet;
action <action>;
// Mandatory entries
source haloToCell;
// Optional entries
steps 1;
| source | Source name: haloToCell | word | yes | - |
| steps | Number of grow/shrink steps to use | label | no | 1 |
Options for the action entry:
add | Add selected cells into this cellSet subtract | Remove selected cells from this cellSet
action=new is not available for haloToCell.Tutorial:
Copyright © 2020 OpenCFD Ltd.
