A topoSetCellSource to select cells with N or less number of neighbouring cells (i.e. number of internal or coupled faces).
Example of the nbrToCell topoSet by using actions sub-dictionary in system/topoSetDict file:
name <name>;
type cellSet;
action <action>;
// Mandatory entries
source nbrToCell;
neighbours <number>;
| source | Source name: nbrToCell | word | yes | - |
| neighbours | Maximum number of neighbour cells | label | yes | - |
Options for the action entry:
Copyright © 2020 OpenCFD Ltd.
