A topoSetCellSource to select cells whose cell centre nearest to given points.
Example of the nearestToCell topoSet by using actions sub-dictionary in system/topoSetDict file:
name <name>;
type cellSet;
action <action>;
// Mandatory entries
source nearestToCell;
points
(<p1x> <p1y> <p1z>)
(<p2x> <p2y> <p2z>)
| source | Source name: nearestToCell | word | yes | - |
| points | List of selection points | vectorList | yes | - |
Options for the action entry:
Copyright © 2020 OpenCFD Ltd.
