A topoSetCellSource to select cells with any point or any edge within a given pointSet(s).
| input | pointSet(s) | $FOAM_CASE/constant/polyMesh/sets/<set> |
Example of the pointToCell topoSet by using actions sub-dictionary in system/topoSetDict file:
name <name>;
type cellSet;
action <action>;
// Mandatory entries
source pointToCell;
option <option>;
// Select either of the below
// Option-1
sets
<pointSetName1>
<pointSetName2>
// Option-2
set <pointSetName>;
| source | Source name: pointToCell | word | yes | - |
| option | Selection type - see below | word | yes | - |
Options for the action entry:
Options for the option entry:
any | Cells using any point in pointSet edge | Cells using an edge with both points in pointSet
Entry | Description | Type | Required | Default sets | Names of input pointSets | wordList | conditional | - set | Name of input pointSet | word | conditional | -
Copyright © 2020 OpenCFD Ltd.
