A topoSetCellSource to select cells belonging to a topologically connected region (that contains given points). If started inside a given subCellSet keeps to it; if started outside stays outside.
| input | region | $FOAM_CASE/constant/{<region>, polyMesh} |
Example of the regionToCell topoSet by using actions sub-dictionary in system/topoSetDict file:
name <name>;
type cellSet;
action <action>;
// Mandatory entries
source regionToCell;
insidePoints
(<p1x> <p1y> <p1z>)
(<p2x> <p2y> <p2z>)
// Optional entries
set <cellSetName>;
nErode <label>;
| source | Source name: regionToCell | word | yes | - |
| insidePoints | Coordinate(s) that is inside connected region | vectorList | yes | - |
| set | Name of cellSet restricting search | word | no | none |
| nErode | Number of cell layers to erode mesh to detect holes in the mesh - set to 0 if not used | label | no | 0 |
Options for the action entry:
Copyright © 2020 OpenCFD Ltd.
