A topoSetCellSource to select cells based on cell centres inside a given parallopiped (i.e. rotated/skewed box).
Example of the rotatedBoxToCell topoSet by using actions sub-dictionary in system/topoSetDict file:
name <name>;
type cellSet;
action <action>;
// Mandatory entries
source rotatedBoxToCell;
origin (<o1> <o2> <o3>);
i (<i1> <i2> <i3>);
j (<j1> <j2> <j3>);
k (<k1> <k2> <k3>);
| source | Source name: rotatedBoxToCell | word | yes | - |
| origin | Origin of the box | vector | yes | - |
| i | x1-axis | vector | yes | - |
| j | x2-axis | vector | yes | - |
| k | x3-axis | vector | yes | - |
Options for the action entry:
Box defined as origin and i,j,k vectors. For example, box rotated 45 degrees around z-axis with sizes sqrt(0.2^2+0.2^2) (and extra large, 200 in z direction):
origin ( 0.4 0.4 -100); i ( 0.2 0.2 0); j (-0.2 0.2 0); k ( 0.0 0.0 100);
Copyright © 2020 OpenCFD Ltd.
