A topoSetCellSource to select cells based on the type of their cell shapes.
Handles all types of cell shapes known from the static collection in cellModel (as shown below) and splitHex with 10 degrees feature angle.
Example of the shapeToCell topoSet by using actions sub-dictionary in system/topoSetDict file:
name <name>;
type cellSet;
action <action>;
// Mandatory entries
source shapeToCell;
shape <shapeTypeName>;
| source | Source name: shapeToCell | word | yes | - |
| shape | Type of cell shape - see below | word | yes | - |
Options for the action entry:
Options for the shape entry:
splitHex | Split-hexahedra cells hex | Hexahedra cells wedge | Wedge cells tetWedge | Tetrahedra-wedge cells prism | Prism cells pyr | Pyramid cells tet | Tetrahedra cells
splitHex hardcoded with internal angle < 10 degrees.
Copyright © 2020 OpenCFD Ltd.
