A topoSetCellSource to select cells based on relation to a surface given by an external file.
surfaceToCell can select:
useSurfaceOrientation, requires closed surface)| Operand | Type | Location |
| input | triSurface | $FOAM_CASE/constant/triSurface/<file> |
Example of the surfaceToCell topoSet by using actions sub-dictionary in system/topoSetDict file:
name <name>;
type cellSet;
action <action>;
// Mandatory entries
source surfaceToCell;
file <surfaceFileName>;
outsidePoints
(<p1x> <p1y> <p1z>)
(<p2x> <p2y> <p2z>)
includeCut false;
includeInside false;
includeOutside true;
nearDistance 0.5;
curvature 1.0;
// Optional entries
useSurfaceOrientation false;
fileType stl;
scale 2.0;
| source | Source name: surfaceToCell | word | yes | - |
| file | The surface "filename" | word | yes | - |
| outsidePoints | List of points that define outside of the surface | vectorList | yes | - |
| includeCut | Flag to include cut cells | bool | yes | - |
| includeInside | Flag to include inside cells | bool | yes | - |
| includeOutside | Flag to include outside cells | bool | yes | - |
| useSurfaceOrientation | Flag to use inherently the orientation of the surface | bool | no | false |
| nearDistance | Near distance to the surface | scalar | yes | - |
| curvature | Surface curvature | scalar | yes | - |
| fileType | The format of the surface file | word | no | "" |
| scale | Surface scaling factor | scalar | no | -1 |
Options for the action entry:
Copyright © 2020 OpenCFD Ltd.
