A topoSetCellSource to select cells based on a target volume of cells. Adapts a plane until it has enough.
Example of the targetVolumeToCell topoSet by using actions sub-dictionary in system/topoSetDict file:
name <name>;
type cellSet;
action <action>;
// Mandatory entries
source targetVolumeToCell;
volume 10;
normal (1 0 0);
// Optional entries
set <cellSetName>;
| source | Source name: targetVolumeToCell | word | yes | - |
| volume | The target volume [m3] | scalar | yes | - |
| normal | The plane normal | vector | yes | - |
| set | Restrict to named cellSet | word | no | "" |
Options for the action entry:
Copyright © 2020 OpenCFD Ltd.
