A topoSetCellSource to convert cellZone(s) to cellSet.
| input | cellZone(s) | $FOAM_CASE/constant/polyMesh/cellZones |
Example of the zoneToCell topoSet by using actions sub-dictionary in system/topoSetDict file:
name <name>;
type cellSet;
action <action>;
// Mandatory entries
source zoneToCell;
// Select either of the below
// Option-1
zones
<cellZoneName0>
<cellZoneName1>
// Option-2
zone <cellZoneName>;
| source | Source name: zoneToCell | word | yes | - |
Options for the action entry:
Entry | Description | Type | Required | Default zones | Names of input cellZones | wordList | conditional | - zone | Name of input cellZone | word | conditional | -
The order of precedence among the conditional mandatory entries from the highest to the lowest is zones, and zone.
Copyright © 2020 OpenCFD Ltd.
