A topoSetSource to convert a cellSet to a cellZone (and associated cellSet).
| input | cellSet | $FOAM_CASE/constant/polyMesh/sets/<set> |
| output 1 | cellSet | $FOAM_CASE/constant/polyMesh/sets/<set> |
| output 2 | cellZone | $FOAM_CASE/constant/polyMesh/cellZones |
Example of the setToCellZone topoSet by using actions sub-dictionary in system/topoSetDict file:
name <name>;
type cellSet;
action <action>;
// Mandatory entries
source setToCellZone;
set <cellSetName>;
| source | Source name: setToCellZone | word | yes | - |
| set | Name of input cellSet | word | yes | - |
Options for the action entry:
new | Create a new cellZone from selected cells of a cellSet add | Add selected cells of a cellSet into this cellZone subtract | Remove selected cells of a cellSet from this cellZone
Copyright © 2020 OpenCFD Ltd.
