A topoSetFaceSource to select all faces whose face centre inside given bounding box(es).
Example of the boxToFace topoSet by using actions sub-dictionary in system/topoSetDict file:
name <name>;
type faceSet;
action <action>;
// Mandatory entries
source boxToFace;
// Select either of the below
// Option-1
boxes
(<minX> <minY> <minZ>) (<maxX> <maxY> <maxZ>) // box-1
(<minX> <minY> <minZ>) (<maxX> <maxY> <maxZ>) // box-2
// Option-2
box (<minX> <minY> <minZ>) (<maxX> <maxY> <maxZ>);
// Option-3
min (<minX> <minY> <minZ>);
max (<maxX> <maxY> <maxZ>);
| source | Source name: boxToFace | word | yes | - |
Options for the action entry:
Entry | Description | Type | Required | Default boxes | Multiple bounding boxes | vectorList | conditional | - box | A single bounding box | vector | conditional | - min | Minimum point for a single box | vector | conditional | - max | Maximum point for a single box | vector | conditional | -
The order of precedence among the conditional mandatory entries from the highest to the lowest is boxes, box or a min-max pair (compatibility with searchableBox).
Copyright © 2020 OpenCFD Ltd.
