A topoSetFaceSource to select all the faces from given cellSet(s).
| input | cellSet(s) | $FOAM_CASE/constant/polyMesh/sets/<set> |
Example of the cellToFace topoSet by using actions sub-dictionary in system/topoSetDict file:
name <name>;
type faceSet;
action <action>;
// Mandatory entries
source cellToFace;
option <option>;
// Select either of the below
// Option-1
sets
<faceSetName1>
<faceSetName2>
// Option-2
set <faceSetName>;
| source | Source name: cellToFace | word | yes | - |
| option | Selection type - see below | word | yes | - |
Options for the action entry:
new | Create a new faceSet from selected cells of cellSet(s) add | Add selected faces of cellSet(s) into this faceSet subtract | Remove selected faces of cellSet(s) from this faceSet
Options for the option entry:
all | All faces of cells in the cellSet both | Faces where both neighbours are in the cellSet
Entry | Description | Type | Required | Default sets | Names of input cellSets | wordList | conditional | - set | Name of input cellSet | word | conditional | -
The order of precedence among the conditional mandatory entries from the highest to the lowest is sets and set.
Copyright © 2020 OpenCFD Ltd.
