A topoSetFaceSource to select faces based on usage in another faceSet.
| input | faceSet | $FOAM_CASE/constant/polyMesh/sets/<set> |
Example of the faceToFace topoSet by using actions sub-dictionary in system/topoSetDict file:
name <name>;
type faceSet;
action <action>;
// Mandatory entries
source faceToFace;
// Select either of the below
// Option-1
sets
<faceSetName0>
<faceSetName1>
// Option-2
set <faceSetName>;
| source | Source name: faceToFace | word | yes | - |
Options for the action entry:
Entry | Description | Type | Required | Default sets | Names of input faceSets | wordList | conditional | - set | Name of input faceSet | word | conditional | -
Copyright © 2020 OpenCFD Ltd.
