A topoSetFaceSource to select faces based on explicitly given face labels.
Example of the labelToFace topoSet by using actions sub-dictionary in system/topoSetDict file:
name <name>;
type faceSet;
action <action>;
// Mandatory entries
source labelToFace;
value
<faceLabel1>
<faceLabel2>
| source | Source name: labelToFace | word | yes | - |
| value | Input face labels | labelList | yes | - |
Options for the action entry:
Copyright © 2020 OpenCFD Ltd.
