A topoSetFaceSource to select faces whose surface normal aligned with a given direction.
Example of the normalToFace topoSet by using actions sub-dictionary in system/topoSetDict file:
name <name>;
type faceSet;
action <action>;
// Mandatory entries
source normalToFace;
normal (1 0 0);
cos 0.01;
| source | Source name: normalToFace | word | yes | - |
| normal | The surface normal direction | vector | yes | - |
| cos | Tolerance angle (range -1, +1), i.e. cosine of angle between the input normal and face normal | scalar | yes | - |
Options for the action entry:
Copyright © 2020 OpenCFD Ltd.
