A topoSetFaceSource to select faces associated with given patch(es).
Example of the patchToFace topoSet by using actions sub-dictionary in system/topoSetDict file:
name <name>;
type faceSet;
action <action>;
// Mandatory entries
source patchToFace;
// Select either of the below
// Option-1
patches
<patchName1>
<patchName2>
// Option-2
patch <patchName>;
| source | Source name: patchToFace | word | yes | - |
Options for the action entry:
Entry | Description | Type | Required | Default patches | Names of patches | wordList | conditional | - patch | Name of patch | word | conditional | -
The order of precedence among the conditional mandatory entries from the highest to the lowest is patches, and patch.
Copyright © 2020 OpenCFD Ltd.
