A topoSetFaceSource to select cells belonging to a topologically connected region (that contains given points).
| input | region | $FOAM_CASE/constant/{<region>, polyMesh} |
Example of the regionToFace topoSet by using actions sub-dictionary in system/topoSetDict file:
name <name>;
type faceSet;
action <action>;
// Mandatory entries
source regionToFace;
set <faceSetName>;
nearPoint <point>;
| source | Source name: regionToFace | word | yes | - |
| set | Name of faceSet restricting search | word | yes | - |
| nearPoint | The point on/near to the region | vector | yes | - |
Options for the action entry:
Copyright © 2020 OpenCFD Ltd.
