A topoSetFaceSource to select faces whose face centre enclosed by a given searchableSurface.
| input | triSurface | $FOAM_CASE/constant/triSurface/<file> |
Example of the searchableSurfaceToFace topoSet by using actions sub-dictionary in system/topoSetDict file:
name <name>;
type faceSet;
action <action>;
// Mandatory entries
source searchableSurfaceToFace;
surfaceType <surfaceTypeName>;
// Optional entries
surfaceName <surfaceName>;
| source | Source name: searchableSurfaceToFace | word | yes | - |
| surfaceType | The searchable surface type | word | yes | - |
| surfaceName | Name for the IOobject | word | no | mesh-name |
Options for the action entry:
Copyright © 2020 OpenCFD Ltd.
