A topoSetFaceSource to convert faceZone(s) to a faceSet.
| input | faceZone(s) | $FOAM_CASE/constant/polyMesh/faceZones |
Example of the zoneToFace topoSet by using actions sub-dictionary in system/topoSetDict file:
name <name>;
type faceSet;
action <action>;
// Mandatory entries
source zoneToFace;
// Select either of the below
// Option-1
zones
<faceZoneName0>
<faceZoneName1>
// Option-2
zone <faceZoneName>;
| source | Source name: zoneToFace | word | yes | - |
Options for the action entry:
Entry | Description | Type | Required | Default zones | Names of input faceZones | wordList | conditional | - zone | Name of input faceZone | word | conditional | -
The order of precedence among the conditional mandatory entries from the highest to the lowest is zones, and zone.
Copyright © 2020 OpenCFD Ltd.
