A topoSetSource to select all faces whose cell-cell centre vector intersects with a given searchableSurface.
| input | triSurface | $FOAM_CASE/constant/triSurface/<file> |
| output 1 | faceSet | $FOAM_CASE/constant/polyMesh/sets/<set> |
| output 2 | faceZone | $FOAM_CASE/constant/polyMesh/faceZones |
Example of the searchableSurfaceToFaceZone topoSet by using actions sub-dictionary in system/topoSetDict file:
name <name>;
type faceZoneSet;
action <action>;
// Mandatory entries
source searchableSurfaceToFaceZone;
surfaceType <surfaceTypeName>;
// Optional entries
surfaceName <surfaceName>;
| name | Name of faceZone | word | yes | - |
| type | Type name: faceZone | word | yes | - |
| source | Source name: searchableSurfaceToFaceZone | word | yes | - |
| surfaceType | The searchable surface type | word | yes | - |
| surfaceName | Name for the IOobject | word | no | mesh-name |
Options for the action entry:
new | Create a new faceZone from selected faces of a faceZone add | Add selected faces of a faceZone into this faceZone subtract | Remove selected faces of a faceZone from this faceZone
Copyright © 2020 OpenCFD Ltd.
