A topoSetSource to select faces based on usage in a faceSet, where the normal vector is used to orient the faces.
| input | faceSet | $FOAM_CASE/constant/polyMesh/sets/<set> |
| output | faceZone | $FOAM_CASE/constant/polyMesh/faceZones |
Example of the setAndNormalToFaceZone topoSet by using actions sub-dictionary in system/topoSetDict file:
name <name>;
type faceZoneSet;
action <action>;
// Mandatory entries
source setAndNormalToFaceZone;
faceSet <faceSetName>;
normal (1 0 0);
| name | Name of faceZone | word | yes | - |
| type | Type name: faceZone | word | yes | - |
| source | Source name: setAndNormalToFaceZone | word | yes | - |
| faceSet | Name of input faceSet | word | yes | - |
| normal | The normal vector for orientation | vector | yes | - |
Options for the action entry:
new | Create a new faceZone from selected faces of a faceZone add | Add selected faces of a faceZone into this faceZone subtract | Remove selected faces of a faceZone from this faceZone
Copyright © 2020 OpenCFD Ltd.
