A topoSetSource to convert a faceSet to a faceZone (and associated faceSet).
| input | faceSet | $FOAM_CASE/constant/polyMesh/sets/<set> |
| output 1 | faceSet | $FOAM_CASE/constant/polyMesh/sets/<set> |
| output 2 | faceZone | $FOAM_CASE/constant/polyMesh/faceZones |
Example of the setToFaceZone topoSet by using actions sub-dictionary in system/topoSetDict file:
name <name>;
type faceZoneSet;
action <action>;
// Mandatory entries
source setToFaceZone;
faceSet <faceSetName>;
| name | Name of faceZone | word | yes | - |
| type | Type name: faceZone | word | yes | - |
| source | Source name: setToFaceZone | word | yes | - |
| faceSet | Name of input faceSet | word | yes | - |
Options for the action entry:
new | Create a new faceZone from selected faces of a faceZone add | Add selected faces of a faceZone into this faceZone subtract | Remove selected faces of a faceZone from this faceZone
faceSet is consistent with the setsToFaceZone, but inconsistent with setToCellZone and setToPointZone. Both of which use set instead.Tutorial:
Copyright © 2020 OpenCFD Ltd.
