A topoSetSource to select all faces in a given faceSet, which are oriented in slave cells of a given cellSet.
| input 1 | faceSet | $FOAM_CASE/constant/polyMesh/sets/<set> |
| input 2 | cellSet | $FOAM_CASE/constant/polyMesh/sets/<set> |
| output | faceZone | $FOAM_CASE/constant/polyMesh/faceZones |
Example of the setsToFaceZone topoSet by using actions sub-dictionary in system/topoSetDict file:
name <name>;
type faceZoneSet;
action <action>;
// Mandatory entries
source setsToFaceZone;
faceSet <faceSetName>;
cellSet <cellSetName>;
// Optional entries
flip false;
| name | Name of faceZone | word | yes | - |
| type | Type name: faceZone | word | yes | - |
| source | Source name: setsToFaceZone | word | yes | - |
| faceSet | Name of input faceSet | word | yes | - |
| cellSet | Name of input cellSet containing the slave cells | word | yes | - |
| flip | Flag to select master/slave cells | bool | no | false |
Options for the action entry:
new | Create a new faceZone from selected faces of a faceZone add | Add selected faces of a faceZone into this faceZone subtract | Remove selected faces of a faceZone from this faceZone
Copyright © 2020 OpenCFD Ltd.
