The AMIWeights function object computes the min/max/average weights of arbitrary mesh interface (AMI) patches, and optionally reports into a text file or writes VTK surfaces of the sum of the weights and mask fields for arbitrarily coupled mesh interface (ACMI) patches.
The motivation for the AMIWeights is to monitor the AMI interpolation weights as cases that employ cyclic AMI patches are sensitive to the quality of these weights, e.g. zero AMI interpolation weights likely lead to a simulation crash.
Output statistics per AMI include:
| input | - | - |
| output file | dat | $POST/<file> |
| output field | vtp | $POST/<AMINames>_{src,tgt}.vtp |
where $POST=$FOAM_CASE/postProcessing/<FO>/<time>.
Example of the AMIWeights function object by using functions sub-dictionary in system/controlDict file:
AMIWeights1
type AMIWeights;
writeFields false;
writePrecision 8;
writeToFile true;
useUserTime true;
region region0;
log true;
timeStart 0;
timeEnd 1000;
executeControl timeStep;
executeInterval 1;
| type | Type name: AMIWeights | word | yes | - |
| writeFields | Write weights as VTK fields | bool | yes | - |
postProcess -func AMIWeights
