The CourantNo function object computes the field of Courant number, i.e. Co, for time-variant simulations.
\[ \text{Co} = \Delta_t \, \tau \]
where \(\Delta_t\) is the time-step size, and \(\tau\) is a characteristic time scale based on the local cell flow scales:
\[ \tau = \frac{1}{2 V} \sum_{faces} \left| \phi_i \right| \]
Here, \(V\) is the cell volume, \(\phi\) the face volumetric flux, and \(\sum_{faces}\) summation is over all cell faces.
The Courant number provides
| input | - | - |
| output file | - | - |
Example of the CourantNo function object by using functions sub-dictionary in system/controlDict file:
Co1
type CourantNo;
rho rho;
field <phi>;
result <fieldResult>;
region region0;
log true;
timeStart 0;
timeEnd 1000;
executeControl timeStep;
executeInterval 1;
| type | Type name: CourantNo | word | yes | - |
postProcess -func CourantNo
The Courant number is stored on the mesh database, using the default name
Co
If the field entry is set to a value other than phi, the default name becomes
Co(<field>)
This name can be overridden by using the result entry.
