The Curle function object computes the acoustic pressure based on Curle's analogy.
Curle's analogy is implemented as:
\[ p' = \frac{1}{4 \pi} \frac{\vec{r}}{| \vec{r} | ^2} \cdot \left( \frac{\vec{F}}{| \vec{r} |} + \frac{1}{c_0}\frac{d\vec{F}}{dt} \right) \]
where
| \( p' \) | = | Curle's acoustic pressure [Pa] or [Pa (m3/kg)] |
| \( c_0 \) | = | Reference speed of sound [m/s] |
| \( \vec{r} \) | = | Distance vector to observer locations [m] |
| \( \vec{F} \) | = | Force [N] or [N (m3/kg)] |
| \( t \) | = | Time [s] |
| input | - | - |
| output file 1 | dat | $FOAM_CASE/postProcessing/<FO>/<time>/<file> |
| output file 2 | surface file | $FOAM_CASE/<outputDir>/<time>/<surfaceName> |
| output field | - | - |
Example of the Curle function object by using functions sub-dictionary in system/controlDict file:
Curle1
type Curle;
input <point|surface>;
output <point|surface>;
patches (<patch1> <patch2> ... <patchN>);
c0 343;
// Conditional mandatory entries (runtime modifiable)
// if input=point
observerPositions (<point1> <point2> ... <pointN>);
// if input=surface
surface <surfaceFileName>; // "inputSurface.obj";
// if output=surface
surfaceType <surfaceType>; // ensight;
formatOptions
vtk
format ascii;
p p;
writePrecision 8;
writeToFile true;
useUserTime true;
region region0;
log true;
timeStart 0;
timeEnd 1000;
executeControl timeStep;
executeInterval 1;
| type | Type name: Curle | word | yes | - |
| patches | Sound generation patch names | wordList | yes | - |
| c0 | Reference speed of sound | scalar | yes | - |
| input | Input type | word | yes | - |
| output | Output type | word | yes | - |
| p | Pressure field name | word | no | p |
| observerPositions | List of observer positions (x y z) | pointList | conditional | - |
| surface | Input surface file name | word | conditional | - |
| surfaceType | Output surface type | word | conditional | - |
| formatOptions | Dictionary of surface format options | dictionary | conditional | - |
Options for the input and output entries:
point | Operand is a set of points surface | Operand is a surface
