The DESModelRegions function object computes an indicator field for detached eddy simulation (DES) turbulence calculations, where the values the indicator mean:
0 = Reynolds-averaged Navier-Stokes (RAS) regions 1 = Large eddy simulation (LES) regions
The DESModelRegions function object can only be executed for DES simulations.
| input | - | - |
Example of the DESModelRegions function object by using functions sub-dictionary in system/controlDict file:
DESModelRegions1
type DESModelRegions;
result DESField;
writePrecision 8;
writeToFile true;
useUserTime true;
region region0;
log true;
timeStart 0;
timeEnd 1000;
executeControl timeStep;
executeInterval 1;
| type | Type name: DESModelRegions | word | yes | - |
| result | Name of DES indicator field | word | no | <FO> |
