The Lambda2 function object computes the second largest eigenvalue of the sum of the square of the symmetrical and anti-symmetrical parts of the velocity gradient tensor.
| input | volVectorField | $FOAM_CASE/<time>/<inpField> |
| output file | - | - |
Example of the Lambda2 function object by using functions sub-dictionary in system/controlDict file:
Lambda21
type Lambda2;
field <inpField>;
result <fieldResult>;
region region0;
log true;
timeStart 0;
timeEnd 1000;
executeControl timeStep;
executeInterval 1;
| type | Type name: Lambda2 | word | yes | - |
postProcess -func Lambda2
