The MachNo function object computes the Mach number as a volScalarField.
The Mach number is a dimensionless quantity representing the ratio of flow velocity past a boundary to the local speed of sound:
\[ M = \frac{|\u|}{\sqrt{\gamma p/\rho}} \]
where
| \(M \) | = | Mach number |
| \(\u \) | = | Velocity |
| \(\gamma \) | = | The ratio of specific heat of a gas at a constant pressure to heat at a constant volume |
| \(p \) | = | Static pressure |
| \(\rho \) | = | Fluid density |
| input | volVectorField | $FOAM_CASE/<time>/<inpField> |
| output file | - | - |
Example of the MachNo function object by using functions sub-dictionary in system/controlDict file:
MachNo1
type MachNo;
field <inpField>;
result <fieldResult>;
region region0;
log true;
timeStart 0;
timeEnd 1000;
executeControl timeStep;
executeInterval 1;
| type | Type name: MachNo | word | yes | - |
postProcess -func MachNo
