The PecletNo function object computes the Peclet number as a surfaceScalarField.
| input | surfaceScalarField | $FOAM_CASE/<time>/<inpField> |
| output file | - | - |
| output field | surfaceScalarField | $FOAM_CASE/<time>/<outField> |
Example of the PecletNo function object by using functions sub-dictionary in system/controlDict file:
PecletNo1
type PecletNo;
rho rho;
field <inpField>;
result <fieldResult>;
region region0;
log true;
timeStart 0;
timeEnd 1000;
executeControl timeStep;
executeInterval 1;
| type | Type name: PecletNo | word | yes | - |
postProcess -func PecletNo
