The XiReactionRate function object writes the turbulent flame-speed and reaction-rate volScalarFields for the Xi-based combustion models.
| input | - | - |
| output file | - | - |
| output field | volScalarField | $FOAM_CASE/<time>/{St,wdot} |
Example of the XiReactionRate function object by using functions sub-dictionary in system/controlDict file:
XiReactionRate1
type XiReactionRate;
region region0;
log true;
timeStart 0;
timeEnd 1000;
executeControl timeStep;
executeInterval 1;
| type | Type name: XiReactionRate | word | yes | - |
