The add function object sums a given list of (at least two or more) fields and outputs the result into a new field, where the fields possess the same sizes and dimensions:
fieldResult = field1 + field2 + ... + fieldN
| input | {vol,surface}<Type>Field(s) | $FOAM_CASE/<time>/<inpField>s |
| output file | - | - |
| output field | {vol,surface}<Type>Field | $FOAM_CASE/<time>/<outField> |
Example of the add function object by using functions sub-dictionary in system/controlDict file:
add1
type add;
result <fieldResult>;
region region0;
log true;
timeStart 0;
timeEnd 1000;
executeControl timeStep;
executeInterval 1;
| type | Type name: add | word | yes | - |
| fields | Names of the operand fields | word | yes | - |
postProcess -func "add(<field1>, <field2>, ..., <fieldN>)"
The add function object is stored on the mesh database, using the default name:
add(<field1>,<field2>,...,<fieldN>)
This can be overridden by using the result entry.
