The blendingFactor function object computes and stores the blending coefficient employed by blended divergence schemes, giving an indicator as to which of the schemes is active across the domain.
Blended schemes combine contributions from two schemes, i.e. \(\phi_1\) and \(\phi_2\), using a weight field, i.e. \(w\), such that the effective scheme value, i.e. \(\phi_\eff\), is computed as follows:
\[ \phi_\eff = w \phi_1 + (1 - w) \phi_2 \]
It follows that when \(w = 1\), the scheme reduces to \(\phi_\eff = \phi_1\); similarly, when \(w = 0\), the scheme reduces to \(\phi_\eff = \phi_2\).
The weight field, i.e. \(w\), is surface field and converted to a volume field for easier post-processing by setting the cell value to one minus the minimum of the face values:
\[ w_c = 1 - \min_{\forall i \in \mathrm{faces}}\left(w_{f,i}\right) \]
This conversion leads to blending indicator field whose values mean:
0 = scheme 0 1 = scheme 1 0-1 = a blend between scheme 0 and scheme 1
| input | - | - |
Example of the blendingFactor function object by using functions sub-dictionary in system/controlDict file:
blendingFactor1
type blendingFactor;
// Mandatory (inherited) entry (runtime modifiable)
field <field>;
phi phi;
tolerance 0.001;
result <fieldResult>;
region region0;
log true;
timeStart 0;
timeEnd 1000;
executeControl timeStep;
executeInterval 1;
| type | Type name: blendingFactor | word | yes | - |
| phi | Name of flux field | word | no | phi |
| tolerance | Tolerance for number of blended cells | scalar | no | 0.001 |
The field and phi entries are used to construct the scheme name to lookup from the fvSchemes dictionary, as:
div(phi,U)
The tolerance entry is used as a threshold when computing the number of cells identified as using each scheme. The tolerance entry must be in the range 0 to 1, excluding the endpoints.
The blending factor is stored on the mesh database, using the default name:
blendingFactor(<field>)
The name can be overridden by using the result entry.
Related:
