The columnAverage function object computes the arithmetic average of given quantities along columns of cells in a given direction for structured-like layered meshes. It is, for example, useful for channel-like cases where spanwise average of a field is desired. However, the columnAverage function object does not operate on arbitrary unstructured meshes.
The columnAverage function object, for each patch face, calculates the average value of all cells attached in the patch face normal direction, and then pushes the average value back to all cells in the column.
The columnAverage function object can be applied to any volume fields, generating a volume field. However, the operation cannot be applied onto surface fields, e.g wallShearStress.
| output file | - | - |
Example of the columnAverage function object by using functions sub-dictionary in system/controlDict file:
columnAverage1
type columnAverage;
patches (<patch1> <patch2> ... <patchN>)
region region0;
log true;
timeStart 0;
timeEnd 1000;
executeControl timeStep;
executeInterval 1;
| type | Type name: columnAverage | word | yes | - |
| patches | Names of patches to collapse onto | word | yes | - |
| fields | Names of the operand fields | word | yes | - |
