The components function object extracts the components of a field and outputs the result into new fields, where the fields possess the same sizes and dimensions.
More than one field input per function object is not allowed. Therefore, for each given field, a separate components function object should be created.
Depending on the base type of the input field, the number of output fields and output suffixes are as follows (the base type cannot be scalar since scalars have no components):
Base type | Number of components | Suffixes vector | 3 | (x y z) sphericalTensor | 3 | (x y z) symmTensor | 6 | (xx xy xz yy yz zz) tensor | 9 | (xx xy xz yx yy yz zx zy zz)
| input | {vol,surface}<Type>Field (Type != Scalar) | $FOAM_CASE/<time>/<inpField> |
| output file | - | - |
| output field | {vol,surface}ScalarField for each component | $FOAM_CASE/<time>/<outField><suffix> |
Example of the components function object by using functions sub-dictionary in system/controlDict file:
components1
type components;
// Mandatory (inherited) entry (runtime modifiable)
field <field>;
region region0;
log true;
timeStart 0;
timeEnd 1000;
executeControl timeStep;
executeInterval 1;
| type | Type name: components | word | yes | - |
Minimal example by using the postProcess utility:
postProcess -func "components(<field>)"
The components function object is not executed for fields whose base type is scalar, e.g. volScalarField, since scalar has a single component which is itself.
The result entry is intentionally omitted by the components function object, therefore the default names for the output fields (i.e. component suffixes) cannot be overridden.
The components function object is stored on the mesh database, using the default name:
<field><component>
For instance, for a field named U.air, resulting the following fields:
U.airx U.airy U.airz
The default names cannot be overridden by using the result entry.
