The continuityError function object computes local, global and cumulative continuity errors for a flux field.
Local continuity error, \(\epsilon_\text{local}\):
\[ \epsilon_\text{local} = \Delta_t \langle |x| \rangle \]
Global continuity error, \(\epsilon_\text{global}\):
\[ \epsilon_\text{global} = \Delta_t \langle |x| \rangle \]
Cumulative continuity, \(\epsilon_\text{cum}\):
\[ \epsilon_\text{cum} += \epsilon_\text{global} \]
where
| \( \Delta_t \) | = | Time-step size |
| \( <.> \) | = | Cell-volume weighted average operator |
| \( x \) | = | \( \nabla \cdot \phi \) |
| \( \phi \) | = | Flux field |
| input | - | - |
| output field | - | - |
Example of the continuityError function object by using functions sub-dictionary in system/controlDict file:
continuityError1
type continuityError;
phi phi;
writePrecision 8;
writeToFile true;
useUserTime true;
region region0;
log true;
timeStart 0;
timeEnd 1000;
executeControl timeStep;
executeInterval 1;
| type | Type name: continuityError | word | yes | - |
| phi | Name of flux field | word | no | phi |
Example by using the postProcess -func utility:
postProcess -func "continuityError(<field1>, <field2>, ..., <fieldN>)"
