The ddt function object computes the Eulerian time derivative of an input volume field for time-variant simulations (not appropriate to steady-state simulations).
| output file | - | - |
Example of the ddt function object by using functions sub-dictionary in system/controlDict file:
ddt1
type ddt;
field <field>;
result <fieldResult>;
region region0;
log true;
timeStart 0;
timeEnd 1000;
executeControl timeStep;
executeInterval 1;
| type | Type name: ddt | word | yes | - |
postProcess -func "ddt(<field>)"
