The ddt2 function object computes the magnitude or magnitude squared of the Eulerian time derivative of an input volume field for time-variant simulations (not appropriate to steady-state simulations).
The result can be further used for determining e.g. variance or RMS values.
| output file | - | - |
Example of the ddt2 function object by using functions sub-dictionary in system/controlDict file:
ddt21
type ddt2;
mag false;
result d@@dt2;
region region0;
log true;
timeStart 0;
timeEnd 1000;
executeControl timeStep;
executeInterval 1;
| type | Type name: ddt2 | word | yes | - |
| fields | Names of the operand fields | wordList | yes | - |
| mag | Compute 'mag' instead of 'magSqr' | bool | no | false |
| result | Name of results | word | no | magSqr(ddt2(@)) |
A list of fields can contain exact names or regular expressions. The token \@\@ in the result name is replaced by the name of the source field. In the special case of a single source field (specified as a non-regex), the \@\@ token checking is suppressed.
The function object will skip over fields that appear to have already been processed (ie, their names are similar to the output names).
