The derivedFields function object computes computes two predefined derived fields, i.e. rhoU, and pTotal, where the defined fields are hard-coded as follows:
| \( rhoU \) | = | \(\rho \u \) |
| \( pTotal \) | = | \(p + 0.5 \rho \mag{\u}^2\) |
| output file | - | - |
Example of the derivedFields function object by using functions sub-dictionary in system/controlDict file:
derivedFields1
type derivedFields;
derived (rhoU pTotal);
rhoRef 1.0;
region region0;
log true;
timeStart 0;
timeEnd 1000;
executeControl timeStep;
executeInterval 1;
| type | Type name: derivedFields | word | yes | - |
| derived | Names of operand fields (rhoU|pTotal) | word | yes | - |
| rhoRef | Reference density for incompressible flows | scalar | no | 1.0 |
