The div function object computes the divergence of an input field.
To execute div function object on an input <field>, a numerical scheme should be defined for div(<field>) in system/fvSchemes.divSchemes.
| input | {surfaceScalar,volVector}Field | $FOAM_CASE/<time>/<inpField> |
| output file | - | - |
Example of the div function object by using functions sub-dictionary in system/controlDict file:
div1
type div;
// Mandatory (inherited) entry (runtime modifiable)
field <field>;
result <fieldResult>;
region region0;
log true;
timeStart 0;
timeEnd 1000;
executeControl timeStep;
executeInterval 1;
| type | Type name: div | word | yes | - |
postProcess -func "div(<field>)"
