The enstrophy function object computes the enstrophy of an input volVectorField.
Enstrophy, i.e. \(\xi\):
\[ \xi = 0.5 \mag{\nabla \times \u}^2 \]
where \(\u\) is the input volVectorField.
| input | volVectorField | $FOAM_CASE/<time>/<inpField> |
| output file | - | - |
Example of the enstrophy function object by using functions sub-dictionary in system/controlDict file:
enstrophy1
type enstrophy;
field <inputField>;
result <fieldResult>;
region region0;
log true;
timeStart 0;
timeEnd 1000;
executeControl timeStep;
executeInterval 1;
| type | Type name: enstrophy | word | yes | - |
postProcess -func enstrophy
