The externalCoupled function object provides a simple file-based communication interface for explicit coupling with an external application, so that data is transferred to- and from OpenFOAM. The data exchange employs specialised boundary conditions to provide either one-way or two-way coupling models.
The coupling is through plain text files where OpenFOAM boundary data is read/written as one line per face (data from all processors collated):
# Patch: <patch name> <fld1> <fld2> .. <fldn> //face0 <fld1> <fld2> .. <fldn> //face1 .. <fld1> <fld2> .. <fldn> //faceN
where the actual entries depend on the boundary condition type:
These text files are located in a user specified communications directory which gets read/written on the master processor only.
In the communications directory the structure will be:
<regionsName>/<patchGroup>/<fieldName>.[in|out]
(where regionsName is either the name of a single region or a composite of multiple region names)
At start-up, the boundary creates a lock file, i.e.:
OpenFOAM.lock
... to signal the external source to wait. During the function object execution the boundary values are written to files (one per region, per patch(group), per field), e.g.:
<regionsName>/<patchGroup>/<fieldName>.out
The lock file is then removed, instructing the external source to take control of the program execution. When ready, the external program should create the return values, e.g. to files:
<regionsName>/<patchGroup>/<fieldName>.in
... and then reinstate the lock file. The function object will then read these values, apply them to the boundary conditions and pass program execution back to OpenFOAM.
Example of the externalCoupled function object by using functions sub-dictionary in system/controlDict file:
externalCoupled1
type externalCoupled;
// Directory to use for data exchange
commsDir "${FOAM_CASE}/comms";
regions
// Region name (wildcards allowed)
<regionName>
// Patch or patchGroup
coupleGroup
// Fields to output in commsDir
writeFields (<fields>);
// Fields to read from commsDir
readFields (<fields>);
initByExternal true;
waitInterval 1;
timeOut 100;
statusDone done; // Any arbitrary status=... value
calcFrequency 1;
This reads/writes (on the master processor) the directory:
comms/region0_region1/TPatchGroup/
with contents:
patchPoints (collected points) patchFaces (collected faces) p.in (input file of p, written by external application) T.out (output file of T, written by OpenFOAM)
The patchPoints/patchFaces files denote the (collated) geometry which will be written if it does not exist yet or can be written as a preprocessing step using the createExternalCoupledPatchGeometry application.
| type | Type name: externalCoupled | word | yes | - |
| commsDir | Communication directory | word | yes | - |
| regions | The regions to couple | word | yes | - |
| initByExternal | Initialization values supplied by external app | bool | yes | - |
| waitInterval | Wait interval in [s] | label | no | 1 |
| timeOut | Timeout in [s] | label | no | 100*waitInterval |
| statusDone | Lockfile status=... on termination | word | no | done |
| calcFrequency | Calculation frequency | label | no | 1 |
None.
