The extractEulerianParticles function object generates particle size information from Eulerian calculations, e.g. VoF. It derives spherical particles by interrogating the Eulerian phase fraction field.
| input | - | - |
| input | - | - |
| output file | - | - |
| output field 1 | scalarField | $OUTPUT/d |
| output field 2 | scalarField | $OUTPUT/soi |
| output field 3 | labelField | $OUTPUT/tag |
| output field 4 | vectorField | $OUTPUT/U |
where $OUTPUT=$FOAM_CASE/<time>/lagrangian/eulerianParticleCloud.
Example of the extractEulerianParticles function object by using functions sub-dictionary in system/controlDict file:
extractEulerianParticles1
type extractEulerianParticles;
faceZone f0;
alpha alpha.water;
alphaThreshold 0.1;
nLocations 0;
U U;
rho rho;
phi phi;
minDiameter 1e-30;
maxDiameter 1e30;
writePrecision 8;
writeToFile true;
useUserTime true;
region region0;
log true;
timeStart 0;
timeEnd 1000;
executeControl timeStep;
executeInterval 1;
| type | Type name: extractEulerianParticles | word | yes | - |
| faceZone | Name of faceZone used as collection surface | word | yes | - |
| alpha | Name of phase indicator field | word | yes | - |
| alphaThreshold | Threshold for alpha field | scalar | no | 0.1 |
| nLocations | Number of injection bins to generate | label | no | 0 |
| U | Name of velocity field | word | no | U |
| phi | Name of flux field | word | no | phi |
| minDiameter | Minimum diameter | scalar | no | SMALL |
| maxDiameter | Maximum diameter | scalar | no | GREAT |
The faceZone defines the particle collection surface, at which the phase fraction field, alpha is interpolated to identify the particle bounds.
Each isolated Eulerian region is converted into the equivalent spherical particle by default. Alternatively, the nLocations entry can be used to agglomerate the face zone to define a set of collection faces across which particle information is gathered. This can be useful to the derive particle spatial distribution. faces into a set of collection zones, for which
The following properties are stored:
nCollectedParticles: number of particles collectedcollectedVolume: volume of collected particlesnDiscardedParticles: number of discarded particlesdiscardedVolume: volume of discarded particles
eulerianInjection tutorial: $FOAM_TUTORIALS/multiphase/interFoam/laminar/vofToLagrangian/eulerianInjectionSource code:
