The fieldAverage function object computes ensemble- and/or time-based field averages, with optional windowing, for a user-specified selection of volumetric and/or surface fields.
Fields are entered as a list of sub-dictionaries, which indicate the type of averages to perform, and can be updated during the calculation. The current options include:
mean: arithmetic mean
\[ \overline{x} = \frac{1}{N}\displaystyle\sum\limits_{i=0}^N x_i \]
prime2Mean: prime-squared mean
\[ \overline{x'}^2 = \frac{1}{N} \displaystyle\sum\limits_{i=0}^N (x_i - \overline{x})^2 \]
base: average over 'time', or 'iteration' (N in the above)window: optional averaging window, specified in 'base' unitsAverage field names are constructed by concatenating the base field with the averaging type, e.g. when averaging field 'U', the name of resultant fields becomes:
UMeanUPrime2MeanInformation regarding the number of averaging steps, and total averaging time are written on a per-field basis to the <functionObject name>Properties dictionary, located in <time>/uniform.
When restarting form a previous calculation, the averaging is continuous or may be restarted using the restartOnRestart option.
The averaging process may be restarted after each calculation output time using the restartOnOutput option or restarted periodically using the periodicRestart option and setting restartPeriod to the required averaging period.
With the subRegion option, also supports fields on function object surface output (e.g., sampledSurfaces).
| input | {vol,surface}<Type>Field(s) | $FOAM_CASE/<time>/<inpField>s |
| output file | - | - |
| output field | {vol,surface}<Type>Field(s) | $FOAM_CASE/<time>/<outField>s |
Example of the fieldAverage function object by using functions sub-dictionary in system/controlDict file:
fieldAverage1
type fieldAverage;
fields
<field name 1>
mean <yes|no>;
prime2Mean <yes|no>;
base <time|iteration>;
windowType exact;
window 10.0;
windowName <name>;
allowRestart true;
<field name N>
mean <yes|no>;
base <time|iter>;
restartOnRestart false;
restartOnOutput false;
periodicRestart false;
restartPeriod 0.002;
region region0;
log true;
timeStart 0;
timeEnd 1000;
executeControl timeStep;
executeInterval 1;
| type | Type name: fieldAverage | word | yes | - |
| fields | Names of the operand fields and averaging options | dict | yes | - |
| restartOnRestart | Restart the averaging on restart | bool | no | false |
| restartOnOutput | Restart the averaging on output | bool | no | false |
| periodicRestart | Periodically restart the averaging | bool | no | false |
| restartPeriod | Periodic restart period | scalar | conditional | - |
| restartTime | One-shot reset of the averaging | scalar | no | GREAT |
| subRegion | Name for alternative objectRegistry | word | no | "" |
Average fields are stored on the mesh database, using the default name constructions:
<field>Mean <field>Prime2Mean
These are written to the standard time directories according to the writeControl setting.
